1997 Mitsubishi Galant no spark
DADDYO67
  • 1997 MITSUBISHI GALANT
Engine Mechanical problem
1997 Mitsubishi Galant 4 cyl Front Wheel Drive Automatic
change broke timing belt, crank sensor, distributor I have no spark at plugs
Friday, July 16th, 2010 AT 9:14 AM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, July 16th, 2010 AT 9:01 PM
