HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Galant
Drivetrain
Transmission
Overdrive
SPONSORED LINKS
1995 Mitsubishi Galant
DAWUD
MEMBER
1995 MITSUBISHI GALANT
Transmission problem
1995 Mitsubishi Galant 4 cyl Four Wheel Drive Automatic
My car gets more rpm then it should. My overdrive button does not work. What in the transmission could cause my overdrive not to kick in?
Sunday, June 1st, 2008 AT 11:11 AM
KHLOW2008
MECHANIC
Hi Dawud,
There are many reasons that can cause the problem and the best is to check the basics.
ATF level.
Clogged trans filter. Dirty or aged ATF.
Others are,
Faulty OD switch or solenoid.
TCM malfunctioniing.
SPONSORED LINKS
Sunday, June 1st, 2008 AT 11:37 AM
Please
login
or
register
to post a reply.
Related Transmission Overdrive Content
1995 Mitsubishi Galant Transmission
1995 Mitsubishi Galant Hi, I Have A 1995 Galant. (Actually My Sons Car) The Transmission Would Not Shift To Overdrive. Runs And...
Asked by
cabman39
1995
MITSUBISHI GALANT
Transmission Issues
My 97 Mitsubishi Galant Is Having Transmisson Problems Check Engine Light Came On Obd Code Is P1750 Solonoid Issues And Wont Let Me Go Into...
Asked by
Nickmen08
1 ANSWER
3 IMAGES
1997
MITSUBISHI GALANT
1992 Mitsubishi Galant Will Not Go In Drive Or...
We Replaced The Engine And Can Not Get The Trans To Go Into Drive Or Overdrive The Overdrive Indicator Does Work On The Dash And Indicate...
Asked by
rteklund
1 ANSWER
1992
MITSUBISHI GALANT
Transmission Problem 1995 Mitsubishi Galant Two Wheel Drive Automatic 145000 Miles On Which Side Of The Engine Of Mitsubishi Galant...
Asked by
hlavovr
1 ANSWER
1995
MITSUBISHI GALANT
How Can I Know If The Trasmission Speed Sensor Is The...
Since I Had This Car The Transmission Didnt Work, Well Some Guys Changed It But Now They Are Telling Me That They Cant Find The Trasmission...
Asked by
suksio
1995
MITSUBISHI GALANT
VIEW MORE
Online car repair manuals
