HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Galant
Engine
Timing Belt
1994 Mitsubishi Galant diogram of timing belt
MARYBEL
MEMBER
1994 MITSUBISHI GALANT
4 CYL
FWD
AUTOMATIC
14,300 MILES
Were are my timing marks on my car
Wednesday, October 13th, 2010 AT 8:40 PM
BLUELIGHTNIN6
MECHANIC
SPONSORED LINKS
Wednesday, October 13th, 2010 AT 8:49 PM
Please
login
or
register
to post a reply.
Related Timing Belt Content
1994 Mitsubishi Galant Timing Belt
Engine Mechanical Problem 1994 Mitsubishi Galant 4 Cyl Two Wheel Drive Automatic How To Set The Points For Timing Belt On Mitsubish...
Asked by
ericel arenas ortiz
1 ANSWER
10 IMAGES
1994
MITSUBISHI GALANT
GUIDE
Timing Belt
Automotive combustion engines require either a timing chain or belt to keep the camshaft to crankshaft correlation correct as part of the design of the engine. A timing belt...
Timing Belt
Where Is The Timing Belt Located On A 1999 Mitsubishi Galant
Asked by
angeld1993
1999
MITSUBISHI GALANT
Timing Belt?
Will It Always Damage The Valves If A Timing Belt Breaks While Running On An Interferance Engine?
Asked by
kevculmstock
1 ANSWER
1991
MITSUBISHI GALANT
2000 Mitsubishi Galant Timing Belt
My Car Stop On The Road. I Had It Towed To The Shop He Told Me That The Crank Sensor Was Bad After The Diagnostic. When He Got Ready To Put...
Asked by
edouble6702
1 ANSWER
2000
MITSUBISHI GALANT
Can My Engine Be Repaired After The Timing Belt Brakes...
My Timing Belt And Upper Cover Broke. Is It Likely That This Can Be Repaired Or Will I Need A New Engine? What Is The Best Way To Find Out?
Asked by
blakeburton
1 ANSWER
1998
MITSUBISHI GALANT
VIEW MORE
SPONSORED LINKS
How to fix an engine that wont start
Serpentine Belt Replacement
Serpentine Belt Replacement Saturn Vue
Online car repair manuals
