1989 Mitsubishi Galant Engine misfiring
ROYDEJ
  • 1989 MITSUBISHI GALANT
  • 4 CYL
  • 250,000 MILES
When starting from cold, my engine idles for a little while, 5 minutes or when the temp approaches normal, no engine check lite, but then starts to misfire until it dies. Then when I tried to start again it wont. Used a spark tester to test all ignition wires including that from coil to the distributor and there was no spark. I can smell unburnt fuel. I measured the ohms according to the Mitsubishi Galant shop manual like the positive to negative and positive to hi-tension terminals and values are ok. Could it be the power transistor. Before the car will run longer time like days before the misfiring occurs but the problem gradually deteriorated that I have no confidence to take the car to the shop a mile away because it might stall.
Friday, June 6th, 2008 AT 3:22 AM
KHLOW2008
  • 41,814 POSTS
Hi roydej,
Were there any battery current supply to coil when the engine could not start?
Though no check light indicates, scan it to see if there are any stored codes.
Friday, June 6th, 2008 AT 8:20 AM
