2001 Mitsubishi Galant Cyllinder misfire
2001 MITSUBISHI GALANT
106,000 MILES • 4 CYL • 2WD • AUTOMATIC
ABHISHEK
My car's 4th cylinder started misfiring lately. The mechanic is asking me $350 to fix it. I want to know how urgent i the problem. If I don't fix it now, is it going to have ripple effects on other parts of the engine.
I appreciate your help.
Thanks,
Best regards,
Abhishek
Jan 5, 2009 at 5:33 AM
Cylinder misfire at no.4 -check the compression and injector
Misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 5, 2009 at 8:10 AM
