My question is the 2nd cylinder wiring to the spark plug is just a coil. TO change that, it costs about 100 bucks, but I havent seen the wire set that actually goes into the coil itself. Are those wires to be changed at all? If so how can I change them?
Cylinder 1 and 3 have regular wires that I found at autozone, but nothing that looks like the wiring for cylinders 2 (where misfire is being detected) and 4, where only coil is present with a 2 by 2" box on top of it.
What should I do to solve this problem? And will chanign the wiring help the jerking and the engine light to stop coming on? Can anybody walk me through the process of changing the wiring?
I appreciate your help,
any input is valuable as i'm new to this and this is my first vehicle.
Also can you let me know if I can drive with this lights on for a while or does it need immediate attention.
Thank you
SPONSORED LINKS
Saturday, December 20th, 2008 AT 1:55 PM
