I have a 2003 Eclipse with not that high of mileage on the engine (70K). It keeps losing antifreeze, and i cant figure out where its leaking from. I have replaced the radiator based on a pin hole size leak it had, but on odd occasions it is missing large amounts of antifreeze anyway. There is no smoke or sign of any through the exhaust. There is at times a small puddle under the radiator after the cars temp sensor goes bezerk. I also had the thermostat replaced earlier than the radiator. The last thing I did was replace the factory hose clamps with steel band tensioning clamps. Still no luck and constantly carrying an extra jug of coolant around is getting old.
Any suggestions would be appreciated.
Mar 25, 2009 at 4:24 PM
