2003 Mitsubishi Eclipse Radiator fans dont come one when en
2003 MITSUBISHI ECLIPSE
MITSOWNER
Engine Cooling problem
2003 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual
Could this problem be due to a faulty thermostat or is there some other temperature sensor switch?
Thanks
Jul 7, 2009 at 4:49 AM
LEONU4
  • 15 POSTS
what about trying crank the engine & turn on ac blower to high. Does the fan come on then? if not I would take a 12 volt test light & check the fuses under the hood & drivers side inst. panel. If fuses are good check for voltage at radiator fans W/key on & ac on. koeo = key on engine off. If there is 11-12 volts to fan motor & it's grounded properly. & not coming on you can pretty much replace the fan motor.
Jun 19, 2020 at 4:58 AM
