2001 Mitsubishi Eclipse brakes + A/C compressor
ELFIQ
  • 2001 MITSUBISHI ECLIPSE
Brakes problem
2001 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic
Hi I have 2 questions
First. I exchange brakes in my car and after that I notice that when i'm driving and I let go steering weal my car start turning left. I didn't happened before so I double check brakes and I bleed them again and nothing help. Any idea what can couse this problem?
Second. My A/C doesn't work. I find out that it's my compressor. Here is a question. Can I exchange it by my self? Is it not against the law, because I read somewhere that u need to be license to do it.
thanks for nay help.
Saturday, March 14th, 2009 AT 9:01 PM
MONTY STEPHENS
  • 79 POSTS
I'm just jumping in on all kinds of questions today. Anyways, have you thought the car might need a front end alignment? Or a low tire will do that also, as well as a brake dragiging
I' did an A/C compressor and didn't have the fancy 134a vacuum pump. I replaced the compressor, the filter/dryer and all the seals. I stuffed rags in the hoses as soon as I opened them up to keep air and mositure out. Then put the new parts on it and cranked it up -- it worked good. (That was on a F150)
One word of caution -- a friend of mine who is a mechanic happened to stop by and recommended tripling the amount of oil that was provided with the R20 to 134a conversion kit.
Monday, March 23rd, 2009 AT 11:14 AM
ELFIQ
So how long it took u to do it? Was it difficult to do it or not that bad?
Monday, March 23rd, 2009 AT 10:25 PM
MONTY STEPHENS
  • 79 POSTS
It took a full 1/2 day. My biggest problem was the expansion valve, some places call it a capillary valve. It got stuck and was not coming out. We had to cut the tubing and trow it away- replacing it with a kit that is mde for that pupose. I think it was easy enough.
Wednesday, March 25th, 2009 AT 11:30 AM
