I have noticed recently that when my a/c is running I hear a rush of air or water that almost sounds like metal against metal or like high pressure steam running through a metal pipe. I know this sounds weird, but I can't explain it any better. It seems to also cause my engine to bog down. The sound comes and goes like in waves. It starts real soft and then gets real loud and then soft again. Then it stops for a minute and starts all over again. The noise does not happen when I have the a/c off, so I am assuming that it has to do with the a/c. Also, I had a new a/c compressor, evaporator, expansion valve, and dryer about 4 months ago. Shortly after it was installed, my timing belt bracket broke and to make a long story short, I had a 2004 engine put in 5 weeks ago. Car runs perfect except for this noise.
Oct 11, 2008 at 1:52 PM
