2000 Mitsubishi Eclipse Leaking in Driverside side floor
ELIZABETH5
Air Conditioning problem
2000 Mitsubishi Eclipse 6 cyl All Wheel Drive Automatic
Everytime I turn on my A/C it leaks and floods my drivers side floor. I am told the problem comes from the A/C, how can I get this repaired? And what do I tell the mechanic when I go in to get it fixed?
Thanks.
Jun 30, 2009 at 10:39 AM
BUDDYCRAIGG
  • 2,262 POSTS
the water is common, but there should be a drain tube that allows it to pour to the outside of the car.
look for a short rubber hose, or sometimes hard plastic pipe,
probably on the passenger side.
down low on the firewall.
see if it's clogged up and keeping the water from coming out.
Jun 30, 2009 at 11:46 AM
