Air Conditioning problem
2000 Mitsubishi Eclipse 6 cyl Front Wheel Drive Automatic 150K miles
The A/C blows out warm air only. I press in ac button and it stays on. Fans in front of the radiator are working. Compressor seems working. Tried to charge a can of R134 but the substance did not want to go in. Checked ac fuse and it is good. Switched ac relay with horn relay and the ac problem was the same. I live in Dallas, TX and it is hot here. I appreciate any input to fix the ac issue.
Thank you
Thank you
Apr 16, 2009 at 8:21 AM
