Check engine light on?
110,000 MILES • 6 CYL • FWD • AUTOMATIC
TRASHER
  • 5 POSTS
My son has a Eclipse GT with a 3.0 V6. The check engine light is on all the time. After having the codes read we were told we had code P1400 with was the "manifold pressure switch".
I pulled it off the manifold and there isn't much to it and re-installed it. The connection was tight and nothing looked wrong as far as the install.
How do you check it out?
Jun 27, 2008 at 1:02 PM
MASTERTECHTIM
  • 4,750 POSTS
are you sure its not a egr code. check the vacuum lines to the egr valve to be sure. if you still need help i will research it in the am.
This video will help us fix it
https://youtu.be/vMwTzURWXmk
Jun 27, 2008 at 1:37 PM
TRASHER
  • 5 POSTS
[quote:81eee2ead0="mastertechtim"]are you sure its not a egr code. check the vacuum lines to the egr valve to be sure. if you still need help i will research it in the am.[/quote:81eee2ead0]
He went to Autozone and they used their scanner to pull the code P1400. Looking it up it was the
"P1400 Manifold Differential Pressure Sensor Circuit Malfunction (Mitsubishi) "
On some Fords it might be the EGR circuit is what I found
Thank you!
Jun 27, 2008 at 2:43 PM
MASTERTECHTIM
  • 4,750 POSTS
you are correct. if you dont have a scanner to watch the pressure voltage of the sensor i would go ahead and replace it due to the most common problem would be a faulty sensor not the computer. let me know
https://images.2carpros.com/forum/automotive_pictures/139033_ac_8.jpg
Jun 27, 2008 at 11:32 PM
TRASHER
  • 5 POSTS
I replaced the sensor and it so far has worked. I cleared the codes by disconnecting the battery. Test drove it and turned if off several times. Let's see if this does it. Thanks for your help!
Jun 28, 2008 at 9:56 AM
TRASHER
  • 5 POSTS
He has been driving it for two days without a light on so hopefully it's fixed. Going to get the smog check tomorrow so I will know for sure after that :)
Jun 29, 2008 at 2:54 PM
MASTERTECHTIM
  • 4,750 POSTS
nice
Jun 30, 2008 at 12:33 PM
BALAJISUBBIAHS
I got the same code for my 2001 Galant LS V6 3.0 L.
EGR is also good.
Can you please let me know the exact part name to change("P1400 Manifold Differential Pressure Sensor Circuit Malfunction (Mitsubishi) ") and approx cost to fix it. Please help. can we change it or we need labour (mechanic to do it) How much it will cost.
Thanks
Balaji Subbiah S.
Jul 10, 2008 at 3:39 AM
TRASHER
  • 5 POSTS
I got the part at Auto Zone since they scanned it for free. It cost $126 :(
It sits on top of your intake manifold and held down with 2 bolts with one electrical connector attached to it
Jul 11, 2008 at 5:21 PM
JTODD1122
My check engine light has been on, and off, for the past few weeks. It will mysteriously come on, then go away a day or up to a week later. I had someone tell me it was a pressure issue, and I seem to be losing radiator fluid quicker than normal. I thought it might have been because my clutch slave cylinder was leaking, but I fixed that and the light was still on. it just recently went off again, and I was wondering if anyone could offer suggestions. I am not in the market to pay someone hundreds of dollars at this point and could really use some advice. thanks
Aug 3, 2020 at 7:49 AM (Merged)
KHLOW2008
  • 41,812 POSTS
Hi jtodd1122,
Thank you for the donation.
When the CEL indicates, an error has been detected in the engine management or emission system and a trouble code has been recorded in the engine computer.
It can range from a loose/bad gas cap to a faulty engine computer and to understand what could be wrong, you would need to retrieve the trouble code.
Autozone provides free scanning services, get it done and and let me know the exact trouble code so I can get the necessary data.
BCKNTOP
My car has the error code P1400 I have been quoted 5 hours labor just to find out what the code means. Is there someone that can help me?
  • 110,248 POSTS
Hi:
The PO1400 is Manifold Differential Pressure Sensor circuit. what is the car doing?
BCKNTOP
It sounds a little hollow, but louder if that makes any sense. I had the radiator replaced about 6 months ago and the check engine ight came n about a week later. I ran over something on the road and it has been on ever Since. I am female and have had various mechanice quote me uppwards of $500.00 just to "Take a look at it" I was told that the P1400 could be alot of different things and it wasn't easy to figure out which it was. times like this I don't like being single. I would apprecaite any advice you can give me.
  • 110,248 POSTS
The code is somewhat generic, and it will require some time to determine what is causing the problem. However, 500 dollars is a bit much. What I suggest is to check around to find someone that is willing to look at it for as little as possible.
You described it as having a hollow sound. Have you checked to make sure the air filter box and intake tube is properly attached? Also, when you hit something on the road, could it have damaged the exhaust?
BCKNTOP
Hi Joe,
I have had friends look at it and was told everything looks fine. The Mechanic that gave me the code yesterday checked the hoses and the air filter and said it all looks good. He told me to go on this site and find out what the problem area was and if it isn't something difficult, he would do the repair, but again, he doesn't like to work on Eclipse's due to the way it is put together. If it is the Manifold Differential Pressure Sensor circuit, what would the Symptoms be? The car sounds like there might be something wrong with the exhaust system. No one I know will touch my car due to the fact that everything is so hard to get to. They don't want to deal with it. The problem is I still need to get it fixed as inexpensively as possible.
GAB4ISO
I just bought this car for my 16 year old son. On the way home the "Service Engine Soon" light went on. What does that mean?
BLACKOP555
  • 10,386 POSTS
it means that there is somethign wrong with the vehicle that the pcm has picked up.
besat thing to do is have it scanned and see what is wrong with it, it will tell you whats wrong!
take it to autozone for a free check, some auto values will do it also.
or you can go to just about any mechanic and pay to have it done.
  • 110,248 POSTS
Hi:
Believe me, I understand. Based on the code, I would believe there is a vacuum leak somewhere on or around the intake. It could cause a noise that you described. Also, check the exhaust for leaks. On this type of car I'm concerned that a change in backpressure may even set the code.
Also, the Manifold Differential Pressure switch (MDP) sits on top of your intake manifold and monitors the air pressure. Check it to see if it's mounted good and maybe unplug it and plug it back in to see if there may be corrosion on the plug. Also, have someone check closely for leaks there, remove the MDP and clean it if carboned up and properly replace it. The more I think of it, the more I think that is where the problem is. You may also want to have the EGR checked for leaks, if it's stuck, or carboned up too.
Let me know what you find, or if you have other questions.
BCKNTOP
Thank you, I will keep you informed. I appreciate all your suggestions!
TONYYANKEE
the service engine light turn on and a couple of days prior i had taken it for an oil change in which they check everything. what could be the cause of it.
updated 7/29/09
thank you for your help i am really thankfull. after carefully checking the engine and making sure everything was good found out that the air filter was not installed correctly after a while the light turned off and everything is running good. once again thank you for your help.
KHLOW2008
  • 41,812 POSTS
Hi tonyyankee,
When the MIL shows, an error has been detected and you need a scan to retrieve the trouble codes to understand the problem and find out the cause.
Autozone or most major parts houses provides the scanning services free. Get the scan done and let me know the exact trouble code so I can explain to you what it means.
LORIV06
purchased from dealership feb 27 09.chk engine light just came on. runs fine, quiet, not under a warranty any longer. what could my light be on for? 1 qt over in oil, and they never changed my oil filter. or could i just nd a tune up..and a fresh oil change/filter.
MONTY STEPHENS
  • 79 POSTS
Any sensor can trigger a code. You can disconnect your battery and clear it and then see if it pops back up.
But either way, codes don't necesarily mean something severe. Its just means something is out od specs. And if the car has X number of running cylces without the problems it'll clear itself if it is a trouble code.
MIKE1P
when i have autozone hook up the computer to get code from computer, check engine lite on, they say nothing happens like the computer is dead they told me a fuse must be blone i checked they are ok what do i do to get the computer to work and send a code to there computer?
MONTY STEPHENS
  • 79 POSTS
The computer is not dead. The computer may have just not stored the code even though a sensor has triggered a check engine problem. A sensor can be out of specs but not meet certain requirements for the computer to register it.
You'll need to just run for a week or two and see if it picks it up. Otherwise, just disconnect your batter for a minute or 2 and clear your code that way (make sure you have your radio code before doing that).
TWAYNERAY
the service engine light came on, so i disconnected the battery after adding approx. .5 gallon of coolant, to bring the coolant level up to full. now the light is still on and the car has begun to stall when it is at idle. If you catch it and hit the throttle, the engine will run just fine. The car runs very well at speed and the only time this happens is when the car is at idle.
Aug 3, 2020 at 7:50 AM (Merged)
  • 75,988 POSTS
Bad idea disconnecting the battery the computer loses it memory when you do that. The computer has to relearn itself could last up to 40 restarts to regain it.
MARYCARTIER
the code says misfire it could be ignition coil,sparkplug wire. i replace the sparkplug wires but the engine light still on.
  • 31,937 POSTS
Hi there,
You will have to clear the ecu code first, then re test for any problem after you have been for a drive.
Mark (mhpautos)
ARMYGOV1
my car caught on fire inside 6 monts ago, just a little wiring got burn't i took it to a shop so that the car would at least run again, so they did just the basic as i asked, the only thing that does not work is the cigarrete lighter which is no big deal to me, however the check engine light stayed on and they asured me that there is nothing wrong, but i would have to pay them more if i wanted all the wiring reconnected, dont have the money for that so i disconnected the battery and plugged it back after a few minutes and took it for a 10 mile drive, the light remained off so it seemed to had reset the computer, however after turning it off and back on again the light came back on, i need it to pass inspection but it will not if the light is on how can i disable the light so that it passes the inspection? i don't have the money to throw away since i lost my job and have 2 kids to feed, and cant find the internal fuse box since i dont have the manual either, please help so that i can be street legal again. thank you in advance and i hope that my small dollar makes a difference.
Aug 3, 2020 at 7:51 AM (Merged)
FLEXY5
  • 512 POSTS
The first thing we need to do is find out what code the computer is kicking out. You should be able to take it to a local parts store and have the computer scanned to retrieve the code. Don't buy any parts yet, just get the code and post back here. We can go from there. If you have any further questions, feel free to give us a shout.
ARMYGOV1
ok the code is po141, ho2s 12 heater condition (heated oxygen sensor bank 1 sensor 2) probable causes 1) OS defective 2) poor connection at OS and 3) check circuit-fuse.
the prices given to me ranged from 70 bucks to 170 buck's give or take depending on the brand and also on wich one needed to be changed out of the 4 it has? so where do i go from here and if i get the part or parts is it easy for me to do it or should i have a pro do it? Thanks again for your help and your quick attention! God bless!
FLEXY5
  • 512 POSTS
The code is being thrown because the heated portion of the O2 sensor isn't working. It is something relatively simple to change, but you need to make sure it is the sensor and not the wiring. Check for visible signs of damage from the fire. If you locate cylinder #1 on your engine, that is bank one. Follow the exhaust manifold down and to the catalytic converter. The second O2 sensor that you find is position two (O2 bank one position two). You should have two per side of the engine (the other side being bank two). From there you can trace the wires to inspect for damage. If you don't find any damage, suspect that the sensor is bad. The other posibility is that the computer is not sending out the voltage to heat it up, but in order to test that, you need to be a little more versed on testing electrical systems. If we need to we can go that route. Let me know what you find and if you need more help.
JACKIE THOMPSON MENDOZA
Looking at the car listed above to buy for $800.00. she states it is a Point A to Point B car. she crashed it two years ago but put a lot of work into to bring it back to life. No air bags. radio does not work and check engine light is on. New radiator last year, new cam shaft and brakes last month. Am i looking at some serious issues with this? Should i move on or do you think its worth the time to invest?
Much and any advice would help
HMAC300
  • 48,601 POSTS
have an auto parts scan for codes to see why check engine light is on. it is $500.00 at least for an air bag and hard telling what else is wrong with it. you decide, we do not advise on things like this.
So depending on what the code is, will tell me the severity of the problem?
HMAC300
  • 48,601 POSTS
it may or may not the code will only tell you what circuit is giving the problem then it has to go from there. it can be a fuel pump or a sensor or even a bad computer or a wiring issue/connection. It really depends on what it is If it is like a 0429/30 code then that is bad converter which is about $600.00 to $800.00 to replace.
BAYMAX90
one day the sound of my exhuast dramatically changed from troaty to something more like a chain saw. Engine seemd to be firing fine, but 30 miles later service engine light came on. Took car to local shop. Got multiple misfire code. New plugs, wires, roter etc installed and car tuned. When I picked up the car, light was out but exhaust still sounded funny. Service engine light came on next day. Took car to an official Mitsu dealer, explained problem and change in exhaust sound. They could n't finad anything but suggeted we reflash the compyer - which I havd them do. I picked up the car. Same strange exhaust sound but light was off. By the time I got the car home - service engine light was on again. I am wondering of the problem isn't tied to the catalytic converter or something in the tuned exhaust system that has failed and caused the change in exhaust sound and maybe adding backpressure that might be affecting the exhaust and tripping the light. Should I have the catalytic converter pulled?
OK I just had Autozone check the engine code and it was P0300 multiple Cylinder misfire which it has been the last two times I've had it in for repairs over the last week. Keeping in mind that I just had new plugs, wires,cap, rotor and tune up one week ago ( which eliminated the service engine light for 1 day - but never affected the change in exhaust sound), then 2 days ago the Mitsu dealer checked it, reflashed the computer, light went off for 24 hours but came back on and the exahuast still does not sound right. The dramatic change in exhaust sound happend right before the light came on for the first time, and all the work to date has not changed the exhuast sound back to what it originally sounded like. This seems like this is a key clue in the problem and I'm wondering if I have a catlytic converter problem which is causing fouling or misfiring. I'm at the point of telling the mechanics to stop doing tuneups and parts replacements and look at the exhaust system - does that sound like the right direction to try?
MASTERTECHTIM
  • 4,750 POSTS
go to auto zone and have the car scanned for codes and get back to us with the code numbers and we can go from there.
BAYMAX90
