1999 Mitsubishi Eclipse the crankshaft
97,650 MILES • 4 CYL • 2WD • MANUAL
SCOTT51
I through 2 rods in my eclipse and one busted straight through my oil pan and i dont know if i have to get a new motor or just replace the crank? How would i replace the crankshaft, if needed to to be replaced? and about how much do u think this would cost?
Dec 29, 2008 at 4:47 PM
  • 31,937 POSTS
Hi there,
The engine must be removed and dismantled to remove the crank, you will have to have a good look at the bores as well as the piston may have damaged the cylinder walls, it may be cheaper to get a re-co or second hand engine, a few phone calls will set you straight.
mark (mhpautos)
Dec 29, 2008 at 9:43 PM
