1999 Mitsubishi Eclipse speedometer
1999 MITSUBISHI ECLIPSE
99,000 MILES • 4 CYL • FWD • MANUAL
MEGAN090X
the speedometer doesnt work, where does the cable hook to the transmission or is there a fuse or something too?
Aug 31, 2008 at 11:43 AM
2CARPRO JACK
  • 11,533 POSTS
Most likely the Vehicle Speed Sensor. It is located on the transmission.Is the check engine light on too? If so, have th ePCM scanned for the codes, this will probably tell you what is wrong with your car
Sep 1, 2008 at 1:12 AM
