1999 Mitsubishi Eclipse Repair Question
1999 MITSUBISHI ECLIPSE
YAYBABY
I was thinking of purchasing a 1999 Mitsubishi Eclipse but in the ad it says "engine knock in low-end block of motor" My first question is what does that mean and how bad is it if you can tell me from just this phrase? My second question is, is it repairable without having to buy a new engine?
Feb 24, 2009 at 3:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Engines can make many different noises and people will describe them as knocks, pings, rattles or thumps. A true "knock" is caused by rod or main bearings hitting against the crankshaft. The general cause of that is either too much space between the bearing and crankshaft or insufficient oil pressure to maintain the distance between the bearing and crankshaft. Sometimes you can use a heavier grade oil so that the oil doesn't leak out of the bearing space so quickly. If you're currently using 5 W 15, go to a 10 W 30 or maybe even a 15 W 50. If you can't make the noise go away with that, either the bearings are too worn or it's a different problem. If the engine has less than a couple hundred thousand miles, the only reason for bearings to go bad would be inadequate maintenance.
Other problems that can result in noises like that are:
Piston slap. That's when the skirt (lower part) of the piston is slightly worn and is enough smaller than the cylinder that the skirt "pops" from one side to the other as the engine runs. It's more of an annoyance than a real problem, especially since piston slap typically goes away as the engine warms up a little. It typically takes just a few seconds to go away. If it's piston slap don't worry about it until the engine is rebuilt. Piston slap is quite common among many of the GM 350's, especially in engines that go short distances a lot or don't get adequate maintenance.
Fuel "pinging". That's when the fuel ignites too quickly and causes a sound like something rattling around inside the engine when you step on the accellerator. Use a fuel octane booster or change the engine timing.
Hydraulic lifter noises sounds more like a tapping sound and is usually caused by inconsistent oil changes.
In my opinion, I would be looking somewhere else to purchase a car. Even if thicker oil solves the knock, it is only a temporary fix and the engine will need a tear down to fix it sooner or later. I would stay away from it unless you have the money and time to put into the vehicle for repairs..
Thanks for using 2CarPros.com!
Feb 24, 2009 at 3:38 AM
