Car shuts off and then drives normally
80,000 MILES • 2.0L • 4 CYL • AUTOMATIC
KRYPTECLIPSE
  • 45 POSTS
This is probably the weirdest thing that has happened to my car. Sometimes when I turn on the car it just shuts off. Other times it shuts off when I come to a stop. I have noticed that when it doesn't shut off is when I keep it accelerated. The check engine light comes on and feels like its going to die. I have recently changed the ECU. I noticed it has been acting up like that afterwards. It does drive a whole lot better than before though. These are also some of the recent changes I have done.
Oil change and filter
egr
O2 sensors
PVC
PVC valve hoses
vacuum hoses
spark plugs and wires
fuel filter
fuel pressure regulator
put a fuel injector cleaner in the tank
fuel pump
air filter
coolant temperature sensor
idle control valve
intake air temperature sensor (IAT)
intake manifold gaskets
seafoam
brake booster hose
Thanks in advance
Jun 23, 2015 at 7:21 AM
  • 31,937 POSTS
Can you get a scan done and post the codes that are logged inn the ECU, that will be a good place to start.
Jun 23, 2015 at 7:03 PM
KRYPTECLIPSE
  • 45 POSTS
there are no codes. everything comes out as clean
Jun 24, 2015 at 12:05 AM
  • 31,937 POSTS
I am thinking that it may be an ignition module, I have seen these (but not on your model) fail intermittently when they get warm and start working when they cool down, when it next fails check for spark and injector pulse.
Jun 24, 2015 at 7:29 AM
