Hi, I ahve a 98 eclipse gsx, I pretty much had the same problem as u with it right now, so if your car stalls wen motor is cold but wen it warms up will stay started but sometimes idols rough, then u need to switch out the idol air controler it is pretty much an easy job to do but could cost u a lil bit of money depending were u get the part, to reach were yours is, it is usually located under the throtle body, you will def. Need to remove someparts to get to it but after replacing that the car should run right. :)
SPONSORED LINKS
Thursday, July 3rd, 2008 AT 1:03 PM
