1996 Mitsubishi Eclipse loss of power
CNCKY
  • 1996 MITSUBISHI ECLIPSE
Other Category problem
1996 Mitsubishi Eclipse 4 cyl Wheel Drive Type unknown Automatic lots miles
Hi. My car shakes when started a little, I've had it worked on a lot, but the guy never seems to fix it. So, seeing as
I've made him rich, and now im poor. Im ready to try myself. Ok it starts really well, seems to run ok on flat ground, but don't idle very well shakes a lot, will die sometimes at a red light(which is the worst!). But the very worst thing is it won't go up hills very well. (Loss of power big time). Motor has been rebuilt, heads been redone, new just about everything. Everything he told me might help it I had done. But it always came back the same. Not much power on a hill. Now that I don't have anything to drive, because I live in the country (lot's of big hills to go up) friends have been telling me things to try. I was told to cut the muffler off? And told it might be a fuel injector? I hate to give up on it, almost everything under the hood is new. Any ideals of what I could try? Im female and don't know a lot about a car. So please use words I'll understand. But I'll try about anything you tell me that might help get it up and on the road again. Thanks for any help I get.
Thursday, January 10th, 2008 AT 8:43 PM
FHRACINA
There are several things that I would suggest that u can try, the problem being that they may have all ready been replaced. A possible Idle Air Control Valve, a clogged fuel filter, a missing leaking or broken vaccum line. If these have not been replaced or checked, try replacing them. Especially the fuel filter. Hope this helps
Wednesday, January 30th, 2008 AT 5:30 PM
CNCKY
The vaccum lines should have been checked and replaced if needed. But anymore im not sure. So I will check them. I don't even know what an idle air control valve is. I'll have to look it up. When I learn what and where it is, I'll check it too.
Thanks alot for your input :idea:
Wednesday, January 30th, 2008 AT 8:18 PM
