1995 Mitsubishi Eclipse Loss of Power
ACAPPA
  • 1995 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • MANUAL
  • 120,000 MILES
I have a Mitsubshi Eclipse GST 1995 and it has lost power when I acelarate it. Checked Spark plugs and cables. When idle I can feel like the engine wants to go off.
Tuesday, August 3rd, 2010 AT 12:22 PM
Lack of acceleration, chugging, hesitating, bogging, misfiring etc. Could be caused by one of the following below:
Test and inspect all the following below-we start here and comeback with the results.
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Friday, August 6th, 2010 AT 6:55 AM
