1996 Mitsubishi Eclipse Car stalls when coming to a stop
KATHIEH
  • 1996 MITSUBISHI ECLIPSE
Engine Performance problem
1996 Mitsubishi Eclipse 4 cyl Two Wheel Drive Automatic 37.000 miles
My car, which is great condition, now whats to stall or almost stall under 25 mph. On the freeway it does great, no problem. It is also now starting to shake a little in the front. Two mechanics has said it change gras, etc. Hope you can help, because I break down. Thanks!
Saturday, February 7th, 2009 AT 11:07 PM
KHLOW2008
  • 41,814 POSTS
Hi Kathieh,
Thank you for the donation.
Your problem seems to be a problem with the idling sircuit and it most likely is caused by the Idle Solenoid Control valve and or idle adjust srew passage clogged.
What is the idling speed after warming up?
Does the idle fluctuate while warming up?
WAs it easy to restart after stalling?
Sunday, February 8th, 2009 AT 3:13 AM
