Car stalls when put in gear
180,000 MILES • 2.7L • 4 CYL • FWD • AUTOMATIC
DIRTYDIBZ
My car starts just fine idles fine but no matter how long you let it warm up it stalls when you put it in gear and as soon as you give it gas it shuts off. Now if I start it then give it gas enough to keep it over a 1000 rpms for ten to fifteen minutes then I can let off the gas slowly and it will idle again on its own and not stall until the next time I start it. Any help is appreciated.
Jan 6, 2017 at 6:04 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole with choke cleaner. if it continues check fuel pressure with a gauge auto parts rent it. See link.
Jan 6, 2017 at 11:01 PM
DIRTYDIBZ
I'll give that a shot and let you know how it goes, thank you
Jan 7, 2017 at 8:42 AM
  • 55,748 POSTS
Hey DIRTYDIBZ,
It sounds like it could be a vacuum leak as well, please follow this guide and get back to us.
Please let us know what you find so it will help others.
Best, Ken
Jan 11, 2017 at 2:49 AM
DIRTYDIBZ
Cleaned the throttle plates and it helped to a point, still going to check for a vacuum leak. Thanks guys much appreciated!
Feb 12, 2017 at 5:25 AM
