1995 Mitsubishi Eclipse cant firgure out the problem
1995 MITSUBISHI ECLIPSE
126,038 MILES • 4 CYL • 2WD • AUTOMATIC
ELDRIDGE25
the other day my eclipse did not want to start later on in the night it started then i drove it and it shut off on me and wouldnt start up again. when you try to start the vehicle it sounds like it is going to start but the rpm gauge doesnt move and it wont kick over. i had the ignition coil replaced and i talked to a few people who said it could be the camshaft sensor or the crankshaft sensor i was trying to see if there was a way i could tell which one it is or if you know which one so i dont have to guess thank you
Jun 30, 2010 at 11:42 AM
IRSHWER
im have a very simmalr problem did you have spark b4 you changed you ingistion coil? cuz i dont have one and i would change out the crank senser b4 doing the camshaft senser
Jul 1, 2010 at 3:03 AM
ELDRIDGE25
no i havent had a spark at all and the rpms dont move when i try to start it so its the crankshaft that is the problem not the camshaft?
Jul 1, 2010 at 7:30 AM
IRSHWER
in your problem id say its the crankshaft yes cuz the camshaft only moves the pistions up and down and the crankshaft actuly cranks the engine to start
Jul 1, 2010 at 8:12 AM
