I replaced my MAF sensor due to truck surging. Not going over 2,500 rpm.
$126.00 fix. Problem solved. Now the problem is missing when accelerating up to around 2,500 rpm seems to smooth out. Can my MAP sensor be causing this? I smell gas after I step out of the truck. I replaced the MAP with one I bought at a local salvage yard. Got my used MAP off of a Pathfinder around 1995-1997 year. i am wondering the odds of both sensors being bad. My question is, can the MAP cause the truck to be sluggish on acceleration? Does it affect the advancing or retarding of the distributor? My spark plugs look good they are not black like when my MAF sensor needed replacing.before I replaced the MAF my plugs were black five minutes after cleaning them and restarting the truck. Does a bad MAP sensor cause the engine to loose power and misfire too? Thank you, JC
Jan 13, 2019 at 11:19 AM
