Misfires
145,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JC-842
  • 181 POSTS
Removed plugs two are black and two are no carbon and wet?? Ignore the image I tried to load a picture of the spark plugs but they didn't upload.
Aug 8, 2021 at 3:28 AM
SQM
  • 6,383 POSTS
Was two of them wet with oil or fuel?
Also what codes are you getting ?
https://youtu.be/vMwTzURWXmk
https://www.2carpros.com/articles/how-to-change-spark-plugs
Please let me know little more info.
Thanks.
Aug 9, 2021 at 7:27 AM
JC-842
  • 181 POSTS
Fuel no oil. Cylinders 3/4 not firing. Cylinder 1/2 fouled out black with smut.
Aug 9, 2021 at 2:59 PM
Good morning,
The first thing I would do is a compression test to be sure the engine internals are good. You should have 140-160 pounds in each cylinder.
Then I would check the fuel pressure as that is a common cause for the engine misfire codes.
Are there any codes that are set?
Aug 11, 2021 at 8:04 PM
JC-842
  • 181 POSTS
Okay, thanks. The compression test is done already 150 per cylinder.
Fuel pressure has not been checked. Can you provide a guide for checking the fuel pressure I'm not sure where to hook the gauges. And do you know where the fuel pressure regulator is located? Thanks, JC
Aug 11, 2021 at 9:39 PM
You will need to T into the line at the fuel rail. I attached a picture for you to view. You can rent a tester kit at a parts store for this procedure.
The regulator is part of the fuel pump assembly. It must be replaced with a pump.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Aug 11, 2021 at 9:53 PM
JC-842
  • 181 POSTS
There were no codes for fuel just the P2311 code for coil4. This number 4 cylinder misfire has been ongoing for a long time. But the car has always ran fine just hard on gas. Last week when I started it. It made a popping noise thru the throttle body and a sound like air leak. I replaced intake manifold and throttle body. But the motor shakes and won't accelerate at all. I have a cheap diagnostics OBD11 scanner.
Yesterday I did get a code I could not identify I think something to do with the transmission 7E9:A/T /7E8 Engine.
Aug 11, 2021 at 10:06 PM
JC-842
  • 181 POSTS
Replaced with pump? Not sure what that means.. can you elaborate a little more on that please?
Aug 11, 2021 at 10:12 PM
Okay, I would remove the valve cover and inspect it under the cover. If it is backfiring, you have had a rocker arm issue. The fact that it backfires indicates that.
https://www.2carpros.com/articles/replace-valve-cover-gasket
Aug 11, 2021 at 10:13 PM
The fuel pump contains the fuel pressure regulator. The part is not available by itself. You replace the entire fuel pump.
Aug 11, 2021 at 10:14 PM
JC-842
  • 181 POSTS
Oh no, you mean inside the gas tank. No way I'm not going there. I'm not a certified mechanic. I'm 70 years old I can't deal with that job. I'll have to let the dealership scan it I guess. This is a guessing game at this point and is getting more expensive by the day.
Aug 11, 2021 at 10:17 PM
JC-842
  • 181 POSTS
Okay, thanks.
Aug 11, 2021 at 10:19 PM
You are welcome.
Let us know if you have any other questions.
Aug 11, 2021 at 10:20 PM
JC-842
  • 181 POSTS
What exactly am I looking for inside the valve cover?
Aug 11, 2021 at 10:21 PM
JC-842
  • 181 POSTS
Roy, what does the backfire indicate? This is my problem I've thought that all along. Do I need a valve job or what??
Thanks, JC
Aug 11, 2021 at 10:26 PM
You are looking for anything broken. The backfiring indicates something in the valve train.
It usually shows up with a compression test.
Aug 11, 2021 at 10:28 PM
JC-842
  • 181 POSTS
Okay, I'll do another compression test and then pull the cover. I know where I can buy a motor for $350.00 complete.
Aug 11, 2021 at 10:32 PM
Okay, keep me updated.
Aug 11, 2021 at 10:52 PM
JC-842
  • 181 POSTS
Will do. I think I'm heading in the right direction now. $250.00 later. I should have figured out the missing and the air sound not to mention the backfire.
But the compression test was good. That I don't understand. If something is collapsed. Oh well, at least it's never full around here. Thank you again I'll be in touch when I find out something. JC
Aug 11, 2021 at 10:56 PM
You are welcome.
Aug 11, 2021 at 10:59 PM
JC-842
  • 181 POSTS
I see nothing unusual Roy... Help
Aug 12, 2021 at 12:25 AM
JC-842
  • 181 POSTS
All the valve springs are working and the lifter's are all working.
Aug 12, 2021 at 5:01 AM
When you get it together, remove 1 plug. Start the engine with the compression gauge in the cylinder and tell me the running compression.
Aug 12, 2021 at 7:15 AM
JC-842
  • 181 POSTS
Okay, that won't be today but I think I found the problem. I'm sure it's the PCM the middle pin on the coil connector should be the ground right?
So connecting a test light to positive battery terminal and test light to middle pin of connector and spinning over the engine my test light should blink on off. But it doesn't. I tried it on every one of my coil connectors not just number four and it doesn't blink on any of them. I'm trying to figure out how to test the wire itself from the coil to the PCM pins but I'm not sure how that's done exactly. I have to put the cover back on before I can start it up.
I guess.
Aug 12, 2021 at 7:27 AM
JC-842
  • 181 POSTS
Roy, I started it up and number one cylinder is 150 and bounced around a little over 150.
Aug 12, 2021 at 7:51 AM
My wiring diagram shows 2 wires on the coils.
Aug 12, 2021 at 7:54 AM
Can you verify the 2 coils and the 3 wires?
Aug 12, 2021 at 8:07 AM
JC-842
  • 181 POSTS
That's correct the brown being the hot and the blue striped wire which is the middle pin on the coil connector when a test light is applied with power from positive side of battery with engine turning over is supposed to cause the test light to blink. But it shows no power at all. Was the running compression test okay?
Put the test light on the negative side and probe the blue stripped wire.
Aug 12, 2021 at 8:10 AM
JC-842
  • 181 POSTS
Ignition on or off??
Aug 12, 2021 at 8:24 AM
Ignition on.
Aug 12, 2021 at 8:27 AM
JC-842
  • 181 POSTS
Thanks Roy there's nothing at all. Only the brown wire is active.
Aug 12, 2021 at 8:31 AM
Okay, is the connector on the coil? Make sure it is then check the blue wire for power. Then start it up and see if the light flashes.
Aug 12, 2021 at 8:45 AM
JC-842
  • 181 POSTS
The blue wire is connected yes I tried the test on each one of the connectors.
Aug 12, 2021 at 8:50 AM
JC-842
  • 181 POSTS
Okay Roy, with engine running testing to blue wire and positive battery terminal light comes on steady and does not blink. That's on all cylinders. Then hooked light to ground side of battery and no light at all.
Aug 12, 2021 at 9:02 AM
JC-842
  • 181 POSTS
Just found something odd. Number one coil does not light up at all so the brown wire will light up but not the blue green wire.
Aug 12, 2021 at 9:09 AM
Then the coil is bad. It is not passing current.
Aug 12, 2021 at 9:20 AM
JC-842
  • 181 POSTS
I tested unhooked in and hooked to the coil if the plug is not connected to the coil it shouldn't matter should it. No current is getting to the coil it s the way I'm looking at it. If I'm wrong I'll try another coil but why are none of the other connection blinking like they should be?
Aug 12, 2021 at 9:34 AM
It must be hooked up to the coil for this test. Is the brown wire hot with battery voltage?
Aug 12, 2021 at 9:36 AM
JC-842
  • 181 POSTS
Yes it was . But I pulled the plug from the cylinder left it plugged to the coil and the plug was firing. I changed the coil to a coil I know to be good and installed the plug it's firing and the brown wire is hot but nothing on the blue wire.
Aug 12, 2021 at 9:48 AM
That is because it is grounded by the ECM.
Aug 12, 2021 at 9:57 AM
