misfire in cylinders three and four
1998 JEEP
120,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
GREGORY GRABITZ
Odd misfire in cylinder three or four. With both spark plug wires on I get a misfire. If I pull number three wire no difference missing . If I pull four no difference it is missing . If I pull both wires i get a double miss . If i put either wire on one at a time that cylinder three or four that I put the wire on will fire, put both back on and it misfires. It will do the same if I pull number three injector wire or number four . Whatever one I put back on without putting the other one back on it will fire.
Oct 9, 2016 at 8:38 AM
HMAC300
  • 48,601 POSTS
with misfires I always have you go to a mechanic because it can be so many things wrong not like they used to be. check compression and for a vacuum leak also check for low fuel pressure auto parts rent guage. otherwise leave it to mechanic because it can be sensors or other things causing it. here is an article on how to do it.
Oct 9, 2016 at 11:55 PM
GREGORY GRABITZ
Fuel pressure is good compression is good . In fact the jeep runs strong taking off and going down the road . Spark is strong , new cap, wires, coil and injectors . When it's idling I don't smell raw gas out of the exhaust. It's my daughter friends jeep she only makes minimum wage and as much as mechanics charge I could replace all the sensors for less. I'm thinking it has a short somewhere but as long as it's going down the road I guess it's good .She is going to get a new car this tax season so maybe I'll leave well enough alone. Thanks for your reply.
Oct 11, 2016 at 12:03 PM
  • 55,658 POSTS
Hey Greg,
It sounds like you have a blown head gasket between to cylinders that is allowing the compression fire ignite the fuel in the opposing cylinder at the wrong time. This is difficult to diagnose because the head must be removed to inspect the gasket. IS the compression a little low but exactly the same in each cylinder?
Oct 14, 2016 at 4:26 PM
