1998 Other Jeep Models will not start
RAYNMARTI
  • 1998 JEEP
  • 6 CYL
  • 4WD
  • 110,000 MILES
The car was running then just stopped running
and would not start again the motor turns over
Tuesday, October 7th, 2008 AT 5:35 PM
BLACKOP555
  • 10,371 POSTS
What do you mean would not start again till the motor tursn over?
Tuesday, October 7th, 2008 AT 7:07 PM
MECHCURT
  • 184 POSTS
First thing to check for are fire and fuel. Turn the switch on and try and hear your fuel pump in the tank run. Then check at the fuel rail the schrader valve and see if you have fuel pressure there. Be careful it will be under pressure. To check for fire, while cranking use a spark tester on one of the plug wires to see if you have fire. Get back to us after you have tried these tests. Thanks Curt
Tuesday, December 2nd, 2008 AT 11:30 PM
BLACKOP555
  • 10,371 POSTS
Thanks for that curt. Always check for pressure with a pressure guage, safer and it will tell you if you have enough pressure, 10psi matters.
Wednesday, December 3rd, 2008 AT 6:22 PM
