1993 Mercury Tracer Won't Leave Park
MRJDL80
i have a 93 tracer 1.9 l at on the floor it wont turn over or leave park i put a jumper wire in the plug at the tranny and now it starts but still wont leave park does a bad nuetral safety switch keep a car from going in gear
Oct 19, 2007 at 9:14 AM
BLACKOP555
  • 10,386 POSTS
no, neutral safety switch prevents car from starting unless in neutral or park. you could have a bad brake switch keeping it from disengaging the lock on the column.
Oct 19, 2007 at 9:16 AM
Suggested Repair
A neutral safety switch keeps the engine from starting unless the shifter is in park or neutral; it does not keep the car from leaving park once it starts. Check the brake switch that releases the shift lock on the column.
Conversation Summary
The owner of a 1993 Mercury Tracer 1.9L said it would not crank or leave park. After jumping a plug at the transmission it starts, but it still will not leave park. They asked whether a bad neutral safety switch can prevent shifting into gear. The expert said no: that switch only prevents starting unless the car is in park or neutral. A faulty brake switch may be keeping the column shift lock from releasing.
