Stalls on right hand turns
DJOE
Have you checked your oil dipstick to see if water is present (oil will be caramel color if contaminated with water)? I had the same experience not too long ago and I had to replace the heads, which had two heat fractures. Your radiator could have started with the heating system: radiator, thermostat, leaking hose or heater core. My fluid leaks started with the heater core and if leaks are constant, the engine temp may be affected. Good luck
Wednesday, August 22nd, 2018 AT 3:16 PM (Merged)
MICHEAL777
  • 10 POSTS
Lol, that was awesome. Reminds me a little of touring in an old biplane a couple years ago. I think I'll give your suggestion a swing and retest the battery. I'll get back to you once I. Ve gotten the results back on it. Thanks!
BECKYA
  • 1996 MERCURY TRACER
  • 4 CYL
  • FWD
96 mercury tracer cut off while driving, starter is turning but engine won't catch - fuel tank is full, all fuses okay, could the fuel injector relay do this? Or do I need a fuel pump? Other suggestions? The serpentine belt is okay, but I can't see the timing belt, nor did I find any pieces of one on the road.
  • 109,867 POSTS
You need to check to see if there is fuel and spark to the engine. If there is, check to make sure the timing belt didn't break.
