1997 Mercury Tracer stoped working
120,000 MILES • 4 CYL • FWD • AUTOMATIC
TWT3JO
i have a 1997 mercury tracer and i was driving it alday and when i left my last stop and was on my way home the car just stoped.didn't make no noise or nothing just stopped and has not started up sense. please help
Nov 21, 2009 at 10:47 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Few things first....
Does the vehicle turn over but doesn't start?
Have you done anything to check for the problem?
If not here is what I need you to do...
Get in you vehicle make sure everything is off. Then turn key to on possition Not Starting, do you hear a hum or buzz sound for about 2 - 3 seconds?
If not could be your Fuel Pump, Fuel Pressure Regulator or the Fuel Pump Relay.
Post finding here...
Mark S
Nov 21, 2009 at 11:26 AM
TWT3JO
I PUT A NEW COIL ON THINKING THAT WAS IT AND IT STILL WOULDN'T START SO THEN WE THOUGHT IT WAS THE TIMING BELT SO PUT THAT ON AND STILL DIDN'T START. BUT IT WAS BACK FIRING SO THEN WE PUT ON THE CRANK SENSOR AND THE IDEAL SENSOR AND NOW IT AINT FIRING AT ALL.
Nov 21, 2009 at 11:32 AM
OBXAUTOMEDIC
  • 3,711 POSTS
When it was back firing, was it throught the exhaust or the intake. If through the exhaust that is an indication of a timing problem. Did you double check that the timing marks lined up properly.
Also I take it when you say it's not firing you don't have any spark at the plugs. Have you checked for Power at the Coil Pack. If no power check fuses.
Nov 22, 2009 at 12:01 PM
