1994 Mercury Tracer No spark, engine won't fire
CIVILCLERK1
  • 1994 MERCURY TRACER
  • 4 CYL
  • FWD
  • 159,000 MILES
The engine will crank normally but will not turn over. Turned off at a gas station and will not start again. Happened twice and had to be towed both times. Replaced coil pack, no luck and still no fire, replaced ignition control module, still no fire. Any ideas? I'm a single mom that desperately needs to get this running!
Tuesday, October 6th, 2009 AT 7:38 PM
AIDAN_80
  • 41 POSTS
Have you had someone look at it? If you haven't already you may just want to have the timing belt checked out. Mine died at 84k because the belt was never changed?
Just a thought. Good luck!
Monday, October 12th, 2009 AT 4:09 PM
