1996 Mercury Sable Power Steering Failure
SHOOK92
  • 6 POSTS
I have a 1996 Merc Sable 3.0 100,000 Miles, Everythng has been good until the other day the power steering quit working with no warning . No noises , the fluid is ok and the belts are good. is it the pump or could it be something else I am not familiar with rack and pinion steering systems
Thank's
May 7, 2007 at 6:47 AM
MERLIN2021
  • 17,250 POSTS
Any leaks at the rack? If not pump is suspect...
May 7, 2007 at 7:41 AM
ROSEWILLOW
  • 5 POSTS
probably the pump
May 7, 2007 at 7:45 AM
Suggested Repair
Inspect the steering rack for leaks. If no leaks are found, suspect the power steering pump and have it checked or replaced.
Conversation Summary
The owner of a 1996 Mercury Sable 3.0 reports that power steering suddenly stopped with no noise, adequate fluid, and good belts, and asks whether the pump or rack is at fault. The expert advises checking the rack for leaks and suspecting the pump if none are found. The owner agrees the pump is the likely cause.
