1995 Mercury Sable No Heat
CODY1031
I have a 1995 mercury sable 3.8 with 190000 miles. My question is the heat does not work and the temp gauge goes to the h. The blower works just cold air comes out and no heat. I just changed the thermostat and the water pump, still no luck what else could it be?
Oct 27, 2007 at 11:15 AM
  • 75,988 POSTS
My question is the heat does not work. Do you mean the blower motor is not coming On, or it comes On but no heat. if so might want to check for a clogged-up hose/stuck heater control valve/air blend door or heater core.
Oct 27, 2007 at 12:03 PM
Suggested Repair
With the blower working but only cold air coming out, check for a clogged heater hose, a stuck heater control valve, a faulty air blend door, or a restricted heater core. The thermostat and water pump have already been replaced.
Conversation Summary
The owner of a 1995 Mercury Sable 3.8 with 190,000 miles reports no heat, cold air from a working blower, and the temperature gauge going to hot. Replacing the thermostat and water pump did not fix it. The expert suggests checking a clogged heater hose, stuck heater control valve, air blend door, or heater core.
