2004 Mercury Sable Andrea M. Butler
91,353 MILES • 6 CYL • FWD • AUTOMATIC
SEXYSCORPION1
I recently bought a 2004 Mercury Sable LS with 24 V Dohc engine and it has a keyless entry. I bought the car at Auto Exhange and it didnot come with a remote and also it did not come with the code for the keyless entry. Where can i find the code for the keyless entry, and whom should i get a remote from because it suppuse to come with one but they didn't give me one.
Sep 3, 2008 at 6:32 PM
2CARPRO JACK
  • 11,533 POSTS
Both can be had at the dealer.You may need to take in the VIN# and registration to get the code for the keyless entry.The remotes will have to be programmed to the car. They can give you a "permanent factory code" for the key pad.The you can program your own code-
1-enter permanent factory code
2-press the 1/2 button within 5 seconds to enter programming mode
3-within 5 seconds enter new code, doors will lock,unlock to verify code, this erases previous codes
the remotes will also need to be programmed.
1-insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock,unlock to verify in programming mode
2- Press any button on new remote, doors will lock, unlock to verify
3-Do the previous step with the second remote, doors will lock unlock to verify.
4- turn ignition off.doors will again lock,unlock to verify
Sep 4, 2008 at 12:56 AM
