I have a 99 mercury sable. When I initially start it, it will not shift out of 1st gear. If I restart the car, it will work just fine after that. It happens every time I go to use my car in the morning.
Monday, October 1st, 2018 AT 10:31 AM
(Merged)
MECHANIC
Have the transmission range sensor checked and tested
(Merged)
BMRFIXIT
MECHANIC
Check for TCM codes
and also scan for TCM data
SPONSORED LINKS
(Merged)
OLD MECHANIC
MEMBER
2003 MERCURY SABLE
6 CYL
FWD
AUTOMATIC
122,880 MILES
My transmission seems to change out just fine with the exception of the hard shift from first to second. The other two shifts are a little hard but not as much.
(Merged)
BMRFIXIT
MECHANIC
Need to scan TCM (tranny control module )
for codes
check fluids
(Merged)
OLD MECHANIC
MEMBER
I did scan it and it has a p1764 code.
(Merged)
TONY113065
MEMBER
1 POST
2003 MERCURY SABLE
6 CYL
FWD
AUTOMATIC
69,000 MILES
Hi
While I was driving on the highway in cruise control set at 60 the car suddenly started to decelerate. I coasted off the road and noticed the car would not go into gear. I have not had any previous problems with the transmission nor any slippage. What are some things that would cause this failure.
