2002 Mercury Sable
TINKS
  • 2002 MERCURY SABLE
  • V8
  • FWD
  • 53,000 MILES
My car ran hot one day, changed coolant resevoir, car still ran hot, flushed system, changed therastat, car still runs hot, now have rusty coolant in resevoir, what is wrong?
Thursday, July 24th, 2008 AT 11:37 PM
TINKS
Thursday, July 24th, 2008 AT 11:44 PM
TEE22
  • 13 POSTS
Any check light on? When your engine warms up pass half way on the temp. Gauge, does your fan turns on? The rusty looks may have been wrong mixture of antifreeze, make sure you use the right coolant for the car with the right mixture, test the pressure cap for leaks, and pressure test the cooling system, making sure there is no leaks especially waterpump, and make sure the water pump belt is good.
Friday, July 25th, 2008 AT 12:36 AM
