1993 Mercury Sable running hot
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
LYNNMOORECHERYL
my car is running hot. radiator is full, coolant is full. fan is running but is hooked up to the battery so it runs all the time. why is it running hot
Apr 2, 2008 at 1:37 AM
BLACKOP555
  • 10,386 POSTS
have you replaced the Thermostat and made sure the water pump was pumping coolant?
Apr 2, 2008 at 1:55 PM
KEEMOSABI
  • 9 POSTS
the water pump on my 97 had plastic impeller inside that split off the shaft and was not moving water internally. Take back off of pump after you get it out to be sure.
Apr 26, 2008 at 3:23 PM
