2002 Mercury Sable
DINO1
  • 2002 MERCURY SABLE
2002 Mercury Sable
drivers side window. I replaced motor and up and down switch and window still does not work all the time
Tuesday, July 14th, 2009 AT 1:26 PM
MVORTEX1
  • 5 POSTS
I had the same issue but it was intermittent. The dealership (luckily it was under warranty) spent a few hundred on replacing what you've already done trying to fix it. You could hear a clicking noise under the dash near the fusebox when the button was pushed. Finally they listened to me and installed a new relay, the problem has never returned since. The part is expensive so a junkyard car ford or otherwise may be the way to go. I would also check the fuses if you already havent done this.
Wednesday, August 5th, 2009 AT 8:11 AM
