how do i take off the inside panel to the front door to get to the widow motor or is it possible to maually just raise window
Mar 5, 2010 at 6:04 AM
✓Experienced Mechanic
If you remove the arm rest and unbolt the backing plate behind the handle, there should only be a few screws to take out. Then, seperate the panel from the door by carefully seperating the clips that hold the two together.
