Engine cylinder misfire?
108,231 MILES • 6 CYL • FWD • AUTOMATIC
MADDOG75
  • 11 POSTS
Got my car back today and they replaced the lift springs in cyl 5 due to a lack of compression.....hopefully that will work. Disreguard last post.....light back on today and back to the dealer with a few choice words!!
Oct 22, 2020 at 4:36 AM (Merged)
MERLIN2021
  • 17,250 POSTS
You need to find out what the results of the compression test was...This will tell you if you need engine work or not...No power on earth will fix a bad valve except replacement!
MADDOG75
  • 11 POSTS
The dealer replaced the valve springs but that didnt work what they found out after I brought the car back was that one of the exhaust valves was no good and they in the process of replacing the whole head.....thank god I got the extended warrenty!!! Thanx for the help.
MERLIN2021
  • 17,250 POSTS
no problem!
