Engine cylinder misfire?
108,231 MILES • 6 CYL • FWD • AUTOMATIC
MARTINT73
my vehicle has a misfire in cylinder 5 and i have had the plugs, wires, coil pack, fuel filter and 2 injectors replaced. it misfires when i am accelerating between 50 and 60 mph
Aug 19, 2010 at 9:12 AM
BDOGG0070
  • 42 POSTS
This sounds like you have low fuel pressure but to be sure these guides will help us fix it
here are two guides to help us fix the problem.
and
Aug 19, 2010 at 9:18 AM
MARTINT73
ok will do because first it was cylinder 3 then 1 then 5 and they checked and there were no vacuum leaks
Aug 19, 2010 at 9:23 AM
BDOGG0070
  • 42 POSTS
Let me know how it goes if you don't mind
Aug 19, 2010 at 10:35 AM
MARTINT73
it ended up being that the coil pack which was already replaced was bad so they got another one from the dealer
Aug 20, 2010 at 8:37 AM
BDOGG0070
  • 42 POSTS
That has happened to me a few times. Thats why I tell people Just because it is new doesn't mean that it is good. Glad you got it figured out! Happy motoring!!
Aug 20, 2010 at 8:41 AM
NIGHTRIDER47520
Ive been fighting a check engine light for 4 months now. Its the same code over and over. The code is P0301, which is a cylinder 1 misfire detected. Ive replaced the plugs, wires, fuel injector, fuel filter, intake gaskets (upper and lower), cleaned the egr, replaced the IAC valve, and ran cleaner through. Ive checked compression in the cylinder and its good. Vehicle runs smooth as silk when its warm and the a/c is off. But if u turn the a/c on its misses at idle or in gear at idle. It drives smooth. It seems to only miss under a load. Ive checked fuel pressure and it seems to be good. Id appreciate all the help I can get. Thank you.
Oct 22, 2020 at 4:32 AM (Merged)
DOCFIXIT
  • 18,828 POSTS
Maybe cam and crank sensor out of sync. Have PCM flashed
NIGHTRIDER47520
ford has run dianostics on car and found nothing to be wrong. but the check engine light remains on and still misses under the load of the a/c. i was thinking possible fuel pressure issue but seems to me that it would do it all the time. so u think the cam sensor and crank sensor are out of sync. should i replace them or have them tested? Im all out of ideas myself.
DOCFIXIT
  • 18,828 POSTS
Yes low fuel pressure can cause miss needs to be 35-65 psi. Having computer flashed will reset all peramiters to factory spec.
BRINK21
Dove straight 600miles yesterday. Car was fine until about two hundred miles to go. Then the check engine came on. I continued to drive and watched the rpms and temp everything seemed fine. Then I got into town and slowed to around 30mph then the car started to jerk badly.....but goes away when I speed up.....On sunday I have to make the same trip to take my daughter back home.....WIll it be ok to drive?
RACEFAN966
  • 5,029 POSTS
You said the engine light came on? So check with you local parts stores and see if one will do a free scan. Get the code and then clear the codes. Get back to me with the code and we will see what the car tells us about what is happening.
CAR CRAZY1
the car skips at idle with a/c on and going down the road under load i replaced plugs and wires did not help. service codes po301,po302.po303,304,305,and upstream o2 sensors are reading lean, any ideas?
ZACKMAN
  • 4,202 POSTS
Replace your DPFE sensor. Common problem with most Fords.
CAR CRAZY1
I figured out it was my coil pack .But i appreiciate you trying.
APRILLE
Well I took it in this morning at a full limp, and got it back at a partial limp. Plug wires now replaced evaporation leak found(under the car where it bottomed out and smashed some kind of valve that regulates gas fumes when you fill up?That was the evap code,I guess). Now my baby is misfiring on cylinders#1 and #5, code P0301. I am supposed to bring it back next week to have the coil pack replaced at $400.00, and he says that "might" fix the problem. I am wodering if this misfire suddenly occurred because I was driving it with the check engine light on for so long(back when it was only an evap code a few days ago)I just can't afford the 'hit and miss' style this is starting to look like. Please help! Merlin2021, thank you for trying! :cry:
MERLIN2021
  • 17,250 POSTS
P0301 is a misffire on cyl #1...So the smashed parts underneath have been fixed? Along with the wires, did they check or replace the plugs? They may have fouled during limp mode operation!
APRILLE
Well, it's come down to this: I feel like I'm being taken, but I'm going in anyway at 10:00. Maybe he really will fix it completely, especially after I have given him this much money(after today, the total will be 500$)....I really have no back up plan, and I am discovering that it's impossible to take care of my kids' needs without a vehicle. I just want to believe that the mechanic will do the right thing and that he will know what he's doing. I have to do something. I tried to get him to look at my conversations with you, and he said no. :cry:
ABIGREDBONE
i have a misfire code and excessive back pressure and when accelerating from a stop in town it pops ,hesitates then runs ok ,could one catalytic converter being plugged or partially plugged? and i can not afford a new one if i drop the y and drill one to two small holes threw the converter can i get away with driving from california to texas which i have already done twice and when i drove it non stop without a rest once going and again back it would lose power completely but i just popped the hood and let it cool down then it was ok but when i lost power it was no response at all in the foot pedal (like i ran out of gas)but did not
Oct 22, 2020 at 4:33 AM (Merged)
OBXAUTOMEDIC
  • 3,719 POSTS
Here is an easy test for checking if a cat is going bad.
Remove the O2 sensor(s) in front of the cat. Take for test drive if runs fine then cat is going bad and you will need to replace it.
LIPPUS
  • 5 POSTS
Engine Mechanical problem
1997 Mercury Sable 6 cyl Front Wheel Drive Automatic
where is cylinder #1 and how do i set at top dead center? a mechanic had told me to remove the plug and stick a screwdriver im there and see if the piston is up,if not remove screwdriver and turn key to rotate and check again.is this logical or is there an easier or better way to do this?
  • 31,937 POSTS
Hi there,
Remove all the spark plugs, and earth the coil lead, with a helper, place you finger over No 1 plug hole (front plug) get your helper to crank the engine , just a key on and off type crank, just enough to turn the engine a little, do this until you feel pressure building up on your finger, this will be the piston starting to compress the air in the cylinder, now with the key off, turn the engine by hand, ( this should be easy with no plugs) till the timing mark on the pulley reaches "0" on the timing scale, this will be TDC No 1.
mark (mhpautos)
JADE4
I have a check engine light flashing. I had it checked and it came up misfiring in cylinders 2, 5, and 6. I changed out the plugs and the plug wires.(changed the wires one at a time). The light is still flashing and had it checked and still comes up the same. Is there some way to check why it is doing it without bringing the car into a shop...strapped for cash at the moment. Thanks for any help By the way the car has 155,000 miles on it
Oct 22, 2020 at 4:34 AM (Merged)
JADE4
By the way, the diagnostic also said that the ignition coil was faulty. Will that make cylanders 2, 5, and 6 missfire? Sorry, don't know much about cars. Thanks for any help
PROBLEMINOHIO
  • 5 POSTS
I can usually go to a local parts store and have them hook up the computer to check the engine light code. They can even reset it to see if it goes away. Autozone does this at no charge.
JUSTINLEE827
Hi my name's Justin, i was sitting at the store the other day with my vehicle in park, so i started reving up the egine to about 3500-4000 rpms, it ran smoothly to about 3000 rpms but after that it started skipping or chugging. and i've noticed it would do that when at a higher rate of speed as well. I also had another question, when my car is idling the rpms will see saw between 500 rpms and 1000 rpms, but in that time the lights will get brighter when i mash the throttle and they get dimmer when i let off of the throttle, any answer would be most appreciated. Justin
BMRFIXIT
  • 19,053 POSTS
If no load on engine you should not be raising the RPM that high as you may cause an internal engine failure
and to prevent that from happening the PCM will shut off injectors to limit the RPM
Reason for it cutting out
JJOHNSON65775
1996 Mercury Sable 1 2 3 misfire what could it be I have replace the coil wires and plugs. please help.
CARADIODOC
  • 34,417 POSTS
Defective injector or burned valve. A cylinder leakage test can identify if a valve is not sealing.
JJOHNSON65775
I just put in new injector and that is not it and the the cylinder are good. Now what to do.
CARADIODOC
  • 34,417 POSTS
Are you saying three different cylinders are misfiring? If so, look for something they have in common. Low fuel pressure is one thing. If you have the dual overhead camshafts, check for a jumped timing belt.
Injectors should be replaced in matched sets so they flow the same amount of fuel. If only one or two are replaced, some cylinders will always run a little lean. The oxygen sensors will detect the unburned oxygen in the exhaust and the Engine Computer will command more fuel from all of the injectors.
If there's a leak in the fresh air tube between the mass air flow sensor and the throttle body, some unmeasured air will get in and there won't be any fuel to go with it. That can result in a lean mixture misfire.
The next thing would be to connect a scanner that displays live sensor data so you can see what the Engine Computer is seeing. That will provide some insight as to whether the computer is commanding the wrong amount of fuel based on an incorrect sensor value, or whether the engine is misfiring in spite of correct sensor values. It takes an experienced mechanic to interpret the sensor readings.
KEITHINKINGNC
When i crank the car the engine sounds like its skipping. All plugs, wires, rotary cap etc have been checked. It has a NEW gas filter. I have to pump the pedal at the right time{constantly} to keep it running. The scanner will not read any codes from it. What is wrong with it?
  • 110,251 POSTS
Have you checked fuel pump pressure? Also, have you checked for vacuum leaks?
  • 110,251 POSTS
Kith, first, thanks for the positive feed back back. It's appreciated. Second, let me know what you find.
KEITHINKINGNC
[quote:ab9f0e74d2="Jacobandnickolas"]Kith, first, thanks for the positive feed back back. It's appreciated. Second, let me know what you find.
Joe[/quote:ab9f0e74d2]I will, thank you. I will let you know the first of the week. Thanks.
EPERRY
  • 21 POSTS
i have a 96 mercury sable that is missing when i'm stoped the engine light is on but the light will start to blink on and off then she will miss even when i'm moving and it seems that she starts to get to much gas and looses all power i had it in the grage but there are too many code to know where to start from will i have to replace all the parts the grage listed?
DYABALLIKL
  • 7 POSTS
the first thing you should check in a situation like this is your spark plugs, those can tell you a whole lot about what's going on in the engine.
your story does remind me of one i read on the main page, though. the pros said to that case that it was probably a faulty fuel pump, yours may be related, but still, start simple, with the plugs.
MADDOG75
  • 11 POSTS
I have a 01 Sable with a code that indicates a misfire in cyl #5 I have tried wires, plugs and coil but nothing helps, do your have any other suggestions?
Oct 22, 2020 at 4:35 AM (Merged)
BIGBOY76
ive been having some troubles with mine misfiring as well and but its in more then 1 cylinder. with my experience im now in search for a catalytic converter. im no expert but a lil something helps
MADDOG75
  • 11 POSTS
I had the converter replaced a few months back due to the engine light blinking and very poor exceleration and idle, I have the car at the dealer right now and they are running alot tests Ill check back in when I know what they say.
Oct 22, 2020 at 4:36 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Two tests you haven't done...Compression test, and test of the fuel injector at #5! Let me know what you come up with!
