2001 Mercury Sable Engine Control Module
137,000 MILES • 6 CYL • FWD • AUTOMATIC
55082M
I've had this car for 2 1/2 years and have had many issues that I think are related. 1) Security alarm turns on at night if doors are locked. It can be locked all day, but only turns on at night. 2) My head lights will turn off sometimes if the Auto is selected. 3) Right front brake turns on while driving warping the rotor. 4) Radiator fan would not shut off and drained battery. 5) The low coolant light comes on randomly. 6) After a car wash the check motor light comes on and car misfires. 7) Humidity also causes low coolant light and check engine light to come on. No codes are in memory when checked and disconnecting the battery usually clears lights on dashboard. I think it's the ECM.
Mar 25, 2009 at 9:28 AM
ZACKMAN
  • 4,202 POSTS
Some problems may be related, but for many they are not.
***Possibly the PCM***
***Could be your sun load sensor or the auto lamp relay***
***Check the wheel hub bearing, and your brake caliper***
***Radiator fan relays***
***Coolant level sensor, inside the coolant reservoir***
***Water leak to the the engine bay, causing shortage to your system***
***Same as water leak to the PCM. No cause and effect to the coolant level sensor.***
Mar 29, 2009 at 4:39 PM
