2001 Mercury Sable Alarm
TWINKEN
  • 2001 MERCURY SABLE
  • 4 CYL
  • 200,000 MILES
How do I disconnect the car alarm. The remote does not work and it is keeping the engine from starting. Do I pull a fuse or disconnect the alarm itself? How do I find the wiring for the alarm to disconnect it?
Tuesday, July 13th, 2010 AT 5:17 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Unfortunately anti theft systems are not that easy to just switch off, that would really defeat the purpose of the system, you can't just pull a fuse or cut a wire, it is far more complex than that, i can post a test procedure for no remote system diagnosis, but you will need some equipment, see caution note below and post back if you feel you are able to do this test and i will post the procedure in full.
https://www.2carpros.com/forum/automotive_pictures/61395_Capture_48.jpg
mark (mhpautos)
Tuesday, July 13th, 2010 AT 8:14 PM
