2000 Mercury Sable computer codes
2000 MERCURY SABLE
2000MERCURYSABLE
Engine Mechanical problem
2000 Mercury Sable 6 cyl Two Wheel Drive Automatic 103k miles
1.TPS code comes up when comuter is scanned.
are my oxygen sensors going bad?
2. in cold weather, car bucks a few times while accelerating until engine is warm.
if i let it warm up before driving in cold weather, drives smoothe.
is TPS code making it do this?
thanks so much for taking the time to answer my question. :-D
Jan 30, 2010 at 8:43 PM
OBXAUTOMEDIC
  • 3,711 POSTS
If the TPS (Throttle Position Sensor) is the only code you get then you most likely need to replace the TPS.
If there were codes for the O2 Sensors then good posibility of on or more going bad.
Yes the TPS can be at fault for cold weather problem.
Jan 30, 2010 at 8:49 PM
2000MERCURYSABLE
[quote:e8a71cfa18="obxautomedic"]Hello,
.[/quote:e8a71cfa18]
thank you for your feedback, it is much appreciated!!!
:-D
Jan 30, 2010 at 9:04 PM
