1999 Mercury Sable shoots out the power steering fluid
KLBREAUX
  • 1999 MERCURY SABLE
Steering problem
1999 Mercury Sable 6 cyl Front Wheel Drive
This car started to leak power steering fluid really bad. It would when first started have normal fluid level. After driving it for a few miles the fluid level would drop to the bottom of the pump and get hard to steer. When shutting the engine off the fluid would squirt out of the breather hole and cover the motor in fluid. After a cool down the fluid level would be about normal except for the amount that sprayed out. I put in a junkyard pump which acted the same. The primary leak was coming from the passenger side of the rack and pinion. I bought a rebuilt one installed it and the same problem occured. I pulled the check valve in the pump and replaced the o ring. One more thing is the oil gets foamy. After working the wheel the foam clears up. But again after driving for 10 or so minutes the fluid level drops and the oils is cavitating, then shut down and oil again sprays out of the fill cap.
Wednesday, December 17th, 2008 AT 10:02 PM
MLNELSON232
I have the same year and make and had the same problem I replaced the pump but found out that it was actually the roccin pinion (racket pininon) there are two rods that conect from the fire wall to yourr wheels on it there is a housing and seal----if it is leaking from there thats the problem ---The first estimate was $800 but I found a shop to do it for $350 I would take it to a midas and ask them to inspect it they look at cars and give estimates for free----hope I could help
Monday, December 22nd, 2008 AT 5:18 PM
