Fluid shoots through hole on power steering cap. It is not over filled. What could cause this?
Tuesday, August 31st, 2010 AT 5:41 PM
BLUELIGHTNIN6
MECHANIC
You didn't turn the steering wheel with the engine off did you? That tends to make them puke fluid out the cap.
I don't know how else it could have gotten on the cap since it's about the highest point in the system, a hose or fitting leak spraying clear up there should be apparant
