1999 Mercury Sable Cooling fan/AC fan not working
1999 MERCURY SABLE
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
HAGANJE
My cooling and AC fans will not kick on. Engine overheats but cools down while air moving through radiator so thermostat working fine. Both fan motors working correctly. Relay working fine. Replaced coolant temp sensor. Both fans still not turning on. Is there another "switch" or "sending unit" that I'm missing? I'm afraid it might be a faulty electrical wire. Any ideas?
May 25, 2010 at 3:39 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
there are 2 relays for the cooling fans, a low speed and high speed cooling fan relay. have you tested both of these?
May 25, 2010 at 4:35 PM
HAGANJE
I switched around all three of the same size relay's in the engine compartment fuse panel. Did not have any effect.
May 25, 2010 at 5:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ok, the a/c compressor switch is likely at fault then
May 25, 2010 at 7:51 PM
