was getting 5 psi on koeo, refrd to alldata should be 37-43 psi, replaced fuel pump got the pressure now, but engine wont start just cranks, not sure what else to check with out and ids
Monday, August 16th, 2010 AT 1:04 AM
BLUELIGHTNIN6
MECHANIC
Fuel filter probably clogged from bad fuel pump, replace fuel filter and prime fuel up by turning key on then off in 5 second intervals, do not crank engine during this time. After several cycles attempt to start engine.
