The pressure cap should be releasing pressure if it gets to typically around 16 psi. For it to be blowing off, it either has to be a damaged cap, a damaged reservoir, or a mismatch between the two. How does it feel going on? From the illustration, it is a threaded type cap. Can it be tightened to the point that it overruns. If nothing looks visibly at fault, like the cap or a damaged rexervoir, I would have the cap pressure checked. It would be worth it to have the parts checked for proper application as well.
SPONSORED LINKS
Saturday, October 9th, 2010 AT 10:49 PM
