1995 Mercury Sable Wont start
JOEYGAINES2169
  • 1995 MERCURY SABLE
  • 6 CYL
  • FWD
  • 60,000 MILES
I have a 1995 Mercury sable 3.8L
the car will crank but not start.
I have changed the fuel filter and fuel pump but still nothing. I checked the lines while trying to start car and no fuel is being pumped and ideas.
Saturday, April 17th, 2010 AT 11:51 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Wednesday, April 21st, 2010 AT 1:13 AM
